Product Tips & Techniques
Tips and Tricks on how to get the most about Maple and MapleSim
This post is to help anyone who is just as frustrated about typesetting in plots
as I was before I solved my problem. (Note: the technique works with the version
2020 and newer and may work with earlier versions.)
Why? Because there is no obvious help in Maple showing what works. (And if folks
can improve what I have posted,  please do so. At least when someone executes
a search for this type of problem, they might see the best approach.)
Goal: typeset a name of a function in any text of a plot.
Approach: According to help, '?plot, typesetting',  one should use the
option(procedure?) typeset.   For example:
"restart;   plots:-setoptions(size = [400, 200]):    `f__1`(x) :=cos(x)*(e)^(-(x^(2))/(4)) :    p1 := plot(`f__1`(x), x = -5..5,                         legend = typeset("function ", `f__1`(x) )  );"
However, what I want in the legend is the expression "`f__1`(x),"not the evaluated
expression. Entering the name with single quotes around the expression leads to this:
p1 := plot(f__1(x), x = -5 .. 5, legend = typeset("function ", 'f__1(x)'))
which is great, except that when I wish to redisplay the plot
plots:-display(p1)
the expression f__1(x)is evaluated.
According to the code completion capability of Maple, the procedure
"Typesetting:-Typeset" exists, and it does not evaluate the function:
p1 := plot(f__1(x), x = -5 .. 5, legend = Typesetting:-Typeset(f__1(x))); plots:-display(p1)
except there is no help regarding this procedure.
It appears that the procedure operates only on one item.
Solution: Hence, the ultimate solution for my problem is to still use the typeset
option, but Typeset any expression.
p1 := plot(f__1(x), x = -5 .. 5, legend = typeset("function ", Typesetting:-Typeset(f__1(x)))); plots:-display(p1)
Again, if you can contribute to this post, I would appreciate it.
Download MaplePrimies_-_Typesetting_in_plots.mw
Time is running out for users of Mathcad® 15 worksheets.
Engineers who need to retain their historical Mathcad project files are faced with a looming deadline to move the content to another file format.
The good news is that Mathcad 15 users can turn to Maple Flow as an effective replacement design calculation tool. Maple Flow is an advanced calculation tool with a free-form layout that makes it easy for engineers to brainstorm, develop, and document their project designs.
Maplesoft now has an efficient migration solution for moving critical Mathcad content to Maple Flow worksheets. This gives engineers a path to safeguard their critical reference designs, mathematical analyses, and engineering test results.
Why are engineers moving from Mathcad 15?
In 2025, some changes are expected that will severely restrict access to Mathcad 15 software. Here’s some background:
  • PTC announced that Mathcad 15 is end-of-sale effective December 2021, restricting license activations for new users.
  • Those existing Mathcad 15 customers who bought multiyear license extensions will see them expire by December 2025. After that, those with subscription licenses will not be able to open the app, and will not be able to access their historic design documents.
  • One of the significant issues engineers are encountering is that the new version of the software is not directly compatible with their historical Mathcad documents. PTC no longer has the right to distribute software versions with a third-party component, and has opted to use a different symbolic calculation engine in Mathcad Prime® that cannot read and edit the legacy files.
  • Another issue is that the Mathcad 15 software does not support Windows 11, so is typically run on Windows 10, a platform that Microsoft will not be supporting after October 2025.
  • Without a reliable way to keep accessing their project work in the Mathcad 15 format, engineers are looking for an alternative design worksheet platform.
As a result, engineers with large repositories of these design files now face converting all the worksheets to a new format or risk losing access to valuable design reports, and the possible regulatory consequences.
Maple Flow as a replacement for Mathcad 15
Engineers who want a long-term stable environment for their critical project work can change their design workflow to use Maple Flow for everyday calculation tasks.
The advanced math features and formatting options in Maple Flow make it a good fit for creating (and updating) design documentation and hand calculations, where engineers combine mathematical equations and variables that change regularly, and show the results in a report.
Maple Flow has a short learning curve, and the range of example templates in the Application Center and the customized training all help users quickly get up to speed with Maple Flow commands and formatting features.
How can I migrate Mathcad 15 content to Maple Flow?
Maplesoft has created a series of migration strategies for users of Mathcad software to transition to Maple Flow for ongoing calculation needs or to meet compliance requirements.
For engineers with a handful of worksheets, or where the calculations only span a few pages, it is relatively quick to reenter the calculations directly in Maple Flow. Some steps will need to be updated to the equivalent Maple Flow function, and there is also the opportunity to use features that are not available in Mathcad 15 (or its successor Mathcad Prime), such as advanced signal processing tools, thermodynamic data, and functionality for the analysis of linear systems.
For engineering firms with large repositories of legacy Mathcad 15 files, Maplesoft has developed a convenient path to migrate batches of content into Maple Flow. Maplesoft Engineering Services guide customers through the migration process and apply an efficient Migration Assistant to move the equations, variable definitions, units, layout, and other supported features from Mathcad 15 worksheets to Maple Flow. The content is mapped to the equivalent Maple Flow functionality, so that calculations can be run and developed further. This allows project worksheets and templates to be recreated with the least investment in time.
This image shows a calculation section before and after batch migration into Maple Flow format:
Ongoing support from Maplesoft
Maple Flow was first launched in 2021 and was developed to give engineers a single tool that can perform mathematical analysis and present results in a professional-looking format. There is built-in support for natural mathematical notation and tracking units, and the development roadmap continues to follow a user-focused approach, so new usability enhancements are regular and relevant.
The current release of Maple Flow gives engineers a path to avoid losing legacy calculations and designs previously stuck in Mathcad 15 worksheets and reuse the content for ongoing project work.
If you would like assistance from Maplesoft with migrating large repositories of design worksheets, please contact Maplesoft Sales.
[This is a contributed article by Alex Beilby, Technical Marketing Mgr, Maplesoft]
To Scan Math with the Maple Calculator and show solution steps in Maple:
1. first scan some math with the calculator (right-clik on any image below and open in a new tab to see it larger)
2. Maple calculator immediately shows the solution if that is what you are looking for:
3. Calculator gives options to show the solution steps in the calculator itself ( footprint button in top-right)
4. Or to upload the math to the MapleCloud (cloud icon with up arrow)
5. Once the math is uploaded, MapleCloud can be loaded on a desktop computer and the file opened from your account's Maple Calculator group of files:
6. Again, the solution and some more details are visible on Maple Cloud:
7. To open this math in Maple, click the blue button to Download the file.
The downloaded file can then be loaded in Maple:
8. The Maple commands to solve this math are shown, and the result.
To show steps in Maple at this point, convert the math to inert form, then run the Student:-Calculus1:-ShowSolution() command on it:
Ex := Int(3.(x^2), x = 0 .. 7)
Int(3*x^2, x = 0 .. 7)
(1)
Integrate
The solution to this integral is:
int(3*x^2, x = 0 .. 7)
343
(1.1)
Student:-Calculus1:-ShowSolution(Ex)
"[[,,"Integration Steps"],[,,(&int;)[0]^73 x^2 &DifferentialD;x],["&EmptyVerySmallSquare;",,"1. Apply the" "constant multiple" "rule to the term" &int;3 x^2 &DifferentialD;x],[,"?","Recall the definition of the" "constant multiple" "rule"],[,,&int;[] f(x) &DifferentialD;x=[] (&int;f(x) &DifferentialD;x)],[,"?","This means:"],[,,&int;3 x^2 &DifferentialD;x=3 (&int;x^2 &DifferentialD;x)],[,,"We can rewrite the integral as:"],[,,3 ((&int;)[0]^7x^2 &DifferentialD;x)],["&EmptyVerySmallSquare;",,"2. Apply the" "power" "rule to the term" &int;x^2 &DifferentialD;x],[,"?","Recall the definition of the" "power" "rule, for n" "<>" "-1"],[,,&int;x^[] &DifferentialD;x=[]],[,"?","This means:"],[,,&int;x^2 &DifferentialD;x=[]],[,"?","So,"],[,,&int;x^2 &DifferentialD;x=(x^3)/3],[,"?","Apply limits of definite integral"],[,,[]-([])],[,,"We can rewrite the integral as:"],[,,343]]6""
(2)
Download MapleCalculatorMathCloudUpload.mw
Plots of physical quantities has significantly improved with Maple 2022. The updated useunits option makes unit conversion errors in plots very unlikely. A lot of time is saved when creating plots of physical quantities where values and units must be correct.
One final source of user errors remains: The manual entry of incorrect units in labels.
Below is a way to avoid such errors by computing labels with units for three prevalent axis labeling schemes.
Other desireable labels are given as a suggestion for future plot label enhancements where plot commands could provide formating functionality.
The rendering on this website adds double brakets ⟦ ⟧ wherever units are used. You have to open the document to see how Maple renders.
NULL
Simple plot example: Solar irradiance in space
G__0 := 1361*Unit('W'/'m'^2)
1361*Units:-Unit(W/m^2)
(1)
G__0*sin(2*Pi*t/(24*Unit('h')))
1361*Units:-Unit(W/m^2)*sin((1/12)*Pi*t/Units:-Unit(h))
(2)
plot(1361*Units:-Unit(W/m^2)*sin((1/12)*Pi*t/Units:-Unit(h)), t = 0 .. 12*Unit('h'))
This plot has inconsistent axis labeling:
The vertical axis has units but no name
The horizontal axis has a name and units but they are not easily distinguishable. Misinterpretation is possible. Due to the close spacing the label could be read as a product of the dimension "time squared" (the time t times hours h is of the dimension time squared). Or the reader confounds name and units. (The use of italic fonts for names and roman fonts for units might not be noticeable and is a convention that is not used everywhere.)
The above labeling should be improved for communication, documentation or publication purposes.
A quick attempt using strings and the options useuints and labels.
plot(1361*Units:-Unit(W/m^2)*sin((1/12)*Pi*t/Units:-Unit(h)), t = 0 .. 12*Unit('h'), useunits = ['d', kW/m^2], labels = ["Time t in days", "Exposure G in kV/m^2"])
Axes are now consistent and can be interpreted unambiguously. Formatting can still be improved.
Unfortunately, using the options useunits (for unit conversion) and labels this way introduces a new source of user error when labels are entered with the wrong units.
A way to address this and to ensure unit error-free plotting of expressions of physical quantities is the following:
Step1: Define two lists, one for the units to display and the other for the names to display
a := [Unit('s'), Unit('W'/'cm'^2)]; b := [t, G]
[t, G]
(3)
Step2: Compute labels from the lists
This step avoids the labeling error: No manual entry of units in labels required.
c := [b[1]/a[1], typeset(b[2]/a[2])]; d := [typeset(b[1], "  ", "&lobrk;", a[1], "&robrk;"), typeset(b[2], "  &lobrk;", a[2], "&robrk;")]; e := [typeset(b[1], "  ", "(", a[1], ")"), typeset(b[2], "  (", a[2], ")")]
[typeset(t, "  ", "(", Units:-Unit(s), ")"), typeset(G, "  (", Units:-Unit(W/cm^2), ")")]
(4)
NULL
Dimensionless labels
 Double brackets
Parenthesis
plot(1361*Units:-Unit(W/m^2)*sin((1/12)*Pi*t/Units:-Unit(h)), t = 0 .. 12*Unit('h'), useunits = a, labels = c)
plot(1361*Units:-Unit(W/m^2)*sin((1/12)*Pi*t/Units:-Unit(h)), t = 0 .. 12*Unit('h'), useunits = a, labels = d)
plot(1361*Units:-Unit(W/m^2)*sin((1/12)*Pi*t/Units:-Unit(h)), t = 0 .. 12*Unit('h'), useunits = a, labels = e)
The axis values equal physical quantities divided by their units. The algebraic equation G*cm^2/W = 0.8e-1, for example, is physically speaking correct. Most functions of Maple can process dimensionless expression of the kind G*cm^2/W if G is given with appropriate physical units.
This way of using physical quantities is consistent with ISO 80000.
Used in Maple to enter units in 2D-Math input mode
Can be confounded with functional notation. Units are therefore often written as a whole word (e.g. seconds instead of s).
NULL
The time to produce the above three plots was about 10 Minutes. The most part was spent to get the typesetting of the second and third plot correct.
What takes significant more time (more a question of hours when Typesetting is used for the first time) are
Labels with "/ cm^(2) "or 1/cm^2 formatting.
This formatting might be preferred but is unfortunately again not free from user errors. (I would probably use it if there was a simple and safe way).
f := [b[1]/a[1], b[2]/`#mrow(mo("W "),mo(" "),mo(" / "),msup(mo("cm"),mn("2")))`]; g := [typeset(b[1], "  ", "&lobrk;", a[1], "&robrk;"), typeset(b[2], "  &lobrk;", (`@`(`@`(Units:-Unit, numer), op))(a[2]), "/", (`@`(`@`(Units:-Unit, denom), op))(a[2]), "&robrk;")]; h := [typeset(b[1], "  ", "(", Unit('s'), ")"), typeset(b[2], "  (", `#mrow(mo("W"),mo(" "),msup(mo("cm"),mn("-2")))`, ")")]
[typeset(t, "  ", "(", Units:-Unit(s), ")"), typeset(G, "  (", `#mrow(mo("W"),mo(" "),msup(mo("cm"),mn("-2")))`, ")")]
(5)
plot(1361*Units:-Unit(W/m^2)*sin((1/12)*Pi*t/Units:-Unit(h)), t = 0 .. 12*Unit('h'), useunits = a, labels = f)
plot(1361*Units:-Unit(W/m^2)*sin((1/12)*Pi*t/Units:-Unit(h)), t = 0 .. 12*Unit('h'), useunits = a, labels = g)
plot(1361*Units:-Unit(W/m^2)*sin((1/12)*Pi*t/Units:-Unit(h)), t = 0 .. 12*Unit('h'), useunits = a, labels = h)
NULL
Remarks
For two reasons, I have not given an example with the often used square brackets [ ] because:
    Maple uses square brackets already for lists and indexing purposes,
    and ISO 80000 uses square brackets as an operator that extracts the unit from a physical quantity (e.g.       [G] = Unit('W'/'cm'^2)).
Adding a unit to each value at axes ticks would definitely be a nice labeling feature for simple units.
Programmatically analyzing the units defined in list a above and converting them in a generic way to a typesetting structure is not possible with a few high-level commands.
For inline quotients like in 1/2, an additional backslash must be entered in 2D-Math: \/
Unit('W')/Unit('cm')^2
Units:-Unit(W)/Units:-Unit(cm)^2
(6)
     This will not prevent evaluation to a normal quotient but the input can be used to create an atomic variable (select with mouse -> 2-D Math -> Atomic Variable)
`#mrow(mfenced(mi("W",fontstyle = "normal"),open = "&lobrk;",close = "&robrk;"),mo("&sol;"),mo("&InvisibleTimes;"),msup(mfenced(mi("cm",fontstyle = "normal"),open = "&lobrk;",close = "&robrk;"),mn("2")),mo("&InvisibleTimes;"))`
(7)
     This makes labeling much easier as compared to typesetting commands (compare to the above statements).
f := [b[1]/a[1], b[2]/`#mrow(mfenced(mi("W",fontstyle = "normal"),open = "&lobrk;",close = "&robrk;"),mo("&sol;"),mo("&InvisibleTimes;"),msup(mfenced(mi("cm",fontstyle = "normal"),open = "&lobrk;",close = "&robrk;"),mn("2")),mo("&InvisibleTimes;"))`]
[t/Units:-Unit(s), G/`#mrow(mfenced(mi("W",fontstyle = "normal"),open = "&lobrk;",close = "&robrk;"),mo("&sol;"),mo("&InvisibleTimes;"),msup(mfenced(mi("cm",fontstyle = "normal"),open = "&lobrk;",close = "&robrk;"),mn("2")),mo("&InvisibleTimes;"))`]
(8)
In any case it is a good idea to read ?plot,typesetting before experimenting with typesetting.
Axes_with_unit_labels.mw
My personal preference is for dimensionless labels.
Note:
The solution to avoid labeling errors works only for Maple 2022 and higher.
Some plot commands do not support plotting with units, or they do not fully support it yet.
A new “Sudoku Puzzle” document is now on Maple Learn! Sudoku is one of the world’s most popular puzzle games and it is now ready to play on our online platform.
This document is a great example of how Maple scripts can be used to create complex and interactive content. Using Maple’s built-in DocumentTools:-Canvas package, anyone can build and share content in Maple Learn. If you are new to scripting, a great place to start is with one of the scripting templates, which are accessible through the Build Interactive Content help page. In fact, I built the Sudoku document script by starting from the “Clickable Plots” template.
A Sudoku puzzle is a special type of Latin Square. The concept of a Latin Square was introduced to the mathematical community by Leonard Euler in his 1782 paper, Recherches sur une nouvelle espèce de Quarrés, which translates to “Research on a new type of square”. A Latin Square is an n by n square array composed of n symbols, each repeated exactly once in every row and column. The Sudoku board is a Latin Square where n=9, the symbols are the digits from 1 to 9,  and there is an additional requirement that each 3 by 3 subgrid contains each digit exactly once.
Mathematical research into Sudoku puzzles is still ongoing. While the theory about Latin Squares is extensive, the additional parameters and relative novelty of Sudoku means that there are still many open questions about the puzzle. For example, a 2023 paper from Peter Dukes and Kate Nimegeers examines Sudoku boards through the lenses of graph theory and linear algebra.
The modern game of Sudoku was created by a 74-year-old Indiana retiree named Howard Garnes in 1979 and published under the name “Number Place”. The game had gained popularity in Japan by the mid-1980s, where it was named “Sudoku,” an abbreviation of the phrase “Sūji wa dokushin ni kagiru,” which means “the numbers must be single”.
Today, Sudoku is a worldwide phenomenon. This number puzzle helps players practice using their logical reasoning, short-term memory, time management, and decision-making skills, all while having fun. Furthermore, research from the International Journal of Geriatric Psychiatry concluded that doing regular brain exercises, like solving a Sudoku, is correlated with better brain health for adults over 50 years old. Additionally, research published in the BMJ medical journal suggests that playing Sudoku can help your brain build and maintain cognition, meaning that mental decline due to degenerative conditions like Alzheimer’s would begin from a better initial state, and potentially delay severe symptoms. However, playing Sudoku will by no means cure or prevent such conditions.
If you are unfamiliar with the game of Sudoku, need a refresher on the rules, or want to improve your approach, the “Sudoku Rules and Strategies” document is the perfect place to start. This document will teach you essential strategies like Cross Hatching:
And Hidden Pairs:
After reading through this document, you will have all the tools you need to start solving puzzles with the “Sudoku Puzzle” document on Maple Learn.
Have fun solving!
We have just released an update to Maple 2023 to address a couple of issues.
  • We’ve had a few reports of people encountering “Kernel connection has been lost” errors, and this update should fix that problem.
  • We fixed a problem involving entering math (specifically, the right curly bracket, } ) using an international keyboard.
If you are experiencing kernel connection problems or use Maple with an international keyboard, you should install this update.
This update is available through Tools>Check for Updates in Maple, and is also available from the Maple 2023.2.1 download page. MapleSim users can get this update from the MapleSim Check for Updates or from the MapleSim 2023.2.1 download page, where you will also find an update to the MapleSim Ropes and Pulleys Library.
A Flow and Maple user wonders why Maple Flow may evaluate to high-precision, floating point numbers compared to the same commands used in Maple that evaluate to simple, concise answers.
We suggest the same results can be achieved by toggling the numeric/symbolic evaluation mode toggle in the Flow math container(s)
primes-flow-evaluation-modes.flow
For more information, please see section 3.5 of the Maple Flow User Manual (Numeric and Symbolic Evaluation Modes).
We have just released updates to Maple and MapleSim.
Maple 2023.2 includes a strikethrough character style, a new unit system, improved behavior when editing or deleting subscripts, improved find-and-replace, better mouse selection of piecewise functions and the contents of matrices, and moreWe recommend that all Maple 2023 users install this update.
This update also include a fix to the problem with setoptions3d, as first reported on MaplePrimes. Thanks, as always, for helping us make Maple better.
This update is available through Tools>Check for Updates in Maple, and is also available from the Maple 2023.2 download page, where you can find more details.
At the same time, we have also released an update to MapleSim, which contains a variety of improvements to MapleSim and its add-ons. You can find more information on the MapleSim 2023.2 download page.
It’s finally here. The mystical treasure that has long been rumoured to lie deep within the labyrinthine halls of Maple Learn is within your grasp at last. The ordeals ahead are treacherous, and most who have ventured in have never returned… but, armed with nothing but your wits and your curiosity, you know you’re prepared to conquer the trials that await you. Can you be the first to uncover the secrets of Maple Learn?
A screenshot of the start screen of 'The Treasure of Maple Learn', which consists of colourful squares spelling the word 'START'.
A screenshot of the first room of the Treasure of Maple Learn. The text reads, 'A distant howl echoes through the dark, misty forest as you tread carefully past the towering trees. Many have walked this path seeking the legendary treasure within Maple Learn, but few have returned. You stop in front of a huge stone door, carved with ancient symbols.'
Surprise! We here at Maplesoft have decided to become game developers. Okay, maybe not really, but we do have one game that we’re excited to be sharing with you all. Introducing: The Treasure of Maple Learn. This series of documents mimics the style of a text-based adventure game, and takes you through a series of puzzles that challenge you to discover for yourself all of what Maple Learn has to offer. It was originally created by myself and a team of other co-op students during the 2021 Maplesoft Hackathon, and I’m very excited to be releasing this updated and polished version of the game. Finally, it’s time to set out on your quest to discover the legendary treasure that lurks within Maple Learn… if you dare.
If you don’t dare, don’t worry, we have other options. You can also check out our new video on Getting Started with Maple Learn, which takes you through everything you need to know to become a Maple Learn expert. And if that’s not enough learning Maple Learn for you, we also have an extensive collection of How-To documents. Want an in-depth look at how to use the plot window? How about an exploration of how to work with linear algebra? Or maybe you want to unleash your artistic side? We’ve got you covered.
So if you’re just getting started with Maple Learn and are looking for a tutorial, you’ve got options—we’ve got a quick video overview, tons of collections of in-depth documentation, and a quest through the treacherous depths of Maple Learn to uncover the secrets that lie within. Pick your poison! (But maybe watch out for literal poison in that labyrinth.)
Advanced Engineering Mathematics with Maple (AEM) by Dr. Lopez is such an art.
Mathematics and Control Theory talks easily in Maple...
Thanks Prof. Lopez. You are the MAN !!
Dr. Ali GÜZEL
The concept of “Maple Learn art” debuted on the MaplePrimes blog in December 2021.  Since then, we’ve come a long way with new Maple Learn features and ever-growing creative minds.  Creating art using mathematical expressions and shapes is a great way to hone both your mathematical skills and your creativity, and is the perfect break from a bout of studying or the like.
I started my own Maple Learn art journey over one year ago.  Let’s see how one’s art can improve over time using new and advanced features!
Art with Shapes, March 2022
This pi-themed pie is simple and cute, but could use some additional features:
Adding Shaded() around Maple Learn shape commands colors them in!
Fun fact: I hand-picked all of the coordinates for that pi symbol.  It was an arduous but rewarding process.  Nowadays, I recommend a new method.  When you create a table in Maple Learn with two number columns, the values are plotted as points.  These points can be clicked and dragged across the plot window, and the table updates automatically to display the new coordinates.  How can you use this to make art?
  1. Create a table as described above.
  2. Move the points with your mouse to create an outline of the desired shape.
  3. Use the coordinates from your table in your geometry command.
Let’s apply these techniques in a newer piece: a full recreation of the spaghetti emoji!
Art with Shapes, August 2023
Would you look at that?!  Fully-shaded colors, a background, and lines of spaghetti noodles that weren’t painstakingly guesstimated combine to create a wonderfully improved piece of art.
Art with Animation, March 2022
Visit the document to see its animation.  Animation is an invaluable feature in Maple Learn, frequently utilized to observe how changing variables affect functions or model a concept.  We’ve harnessed its power for animated artwork!  This animation is cute, using parametric functions and more to change the image as the animation variable changes.  Like the previous piece, it’s missing a background, and the leaves overlap the stem awkwardly in some places.
Art with Animation, August 2023
This piece has a simple background made with a large black square, but it enhances the overall effect.
The animation here comes from piecewise functions, which display different values based on a given criterion.  In this case, the criterion is the current value of the animation variable.
There are 32 individual polygons in this image (including 8 really tiny ones along the edges!) and 8 rainbow colors.  Each color is associated with a different piecewise function, and displays four random squares in that color in each frame of the animation.
This image isn’t that much more advanced than the animated flower, but I think the execution has vastly improved.
Whether you’ve been following these blog posts since December 2021 or are new to Maple Learn, we hope you give Maple Learn art a try.
And don’t forget that Maple is also a goldmine of artistic potential.  Maple’s bountiful collection of packages such as Fractals, ColorTools, plottools and more are great places to start for math that is as aesthetically pleasing as it is informative.
This week, our staff participated in a series of art challenges using either Maple Learn or Maple itself, each featuring a suggested theme and suggested mathematical content.  Check out the challenges and some of our employees’ entries below, and try out a challenge for yourself!
Tuesday’s Art Theme: Pasta
Mathematical Content: Shapes
Example: Lazar Paroski’s spiraling take on spaghetti
Wednesday’s Art Theme: Nature
Mathematical Content: Fractals
Example: John May’s Penrose tiling landscape (in Maple!)
Thursday’s Art Theme: Disco
Mathematical Content: Animation
Example: Paulina Chin’s disco ball (in Maple!)
Friday’s Art Theme: Space
Mathematical Content: Color
Example: that’s today!  Who knows what our staff will create…?
We hope these prompts have inspired you! If you create some art you’re really proud of, consider submitting it to be featured in the 2023 Maple Conference’s Creative Works Showcase.
Hi
It's been years since expressions like A %* B %+ C involving inert arithmetic operators used in infix form are correctly understood (parsed) when written on a 1D-Math input line. The idea is simple: have the operators %. %*, %+, %-, %^, %/ work on input as infix operators the same way their active forms: ., *, +, -, ^, / do. This useful functionality, however, remained elusive when using 2D-Math input notation, so one would have to resort to using the functional form of the operators. E.g., input the above as `%+`(`%*`(A, B) ,C), which for me is really ugly. Besides being a bit demoralizing: we do all this fuzz about how great computer algebra and 2D-Math input notation is, and then input things in that way …
So this is to mention that this elusive functionality of inert arithmetic operators used in infix form within a 2D-Math input line now works. The novelty is present in the latest Maplesoft Physics Updates for Maple 2023, which is version 1490. As usual, to install the Updates open a Maple worksheet and input Physics:-Version(latest).
Here is an image (worksheet at the end) showing the new thing
The implementation is pretty new; reports of anything related to these inert operators not displayed/working as you'd expect are much appreciated.
Download Inert_arithmetic_operators_in_2D_Math.mw
Edgardo S. Cheb-Terrab
Physics, Differential Equations and Mathematical Functions, Maplesoft
Maple introduced "Copy as LaTeX" a few versions ago and I have used this feature exensively when it suddenly stopped working.
After som experiments I found the root cause and easy (but irritating) workaround for OSX
Problem:
"Copy as LaTeX" suddenly stops working ("Copy as MathML" still works fine)
Cause:
This problem appears if in “Display Setting”-tab in settings dialogue the “Input display” is set to “Maple Notation
In that case all attempts on “Copy as LaTeX” will be a null-function and not move anything at all into the copy buffer.
The “Copy as MathML” is not affected by this in the same way.
I have confirmed this on OSX in Maple versions 2022, 2023, and 2024
Workaround:
Adjusting “Display Setting”-tab in settings dialogue so that the “Input display” is set to “2-D Math” and “Apply Globally” makes it work again.
A bit annoying as a prefer the maple notation input and I cannot have this setting if I want the copy to latex to work.
Note:
in OSX this can also be fixed by removing the Maple preferences file and letting Maple restore it.
~/Library/Preferences/Maple/2023/Maple Preferences
Edit: Added 2024 as affected version.
Maple's fsolve command can quickly solve expressions involving large floating point numbers where the (symbolic) solve command can take much longer attempting to solve the equivalent rational expression. For example, consider the following worksheet:
restart;
sys := {a + b^0.2784982189 = c+1, b + c^0.9575068354 = a+2, c + a^0.1576130817 = b+3};
{a+b^.2784982189 = c+1, b+c^.9575068354 = a+2, c+a^.1576130817 = b+3}
(1)
fsolve_start:=time[real]():
fsolve(sys);
{a = 3.561242843, b = 1.994950678, c = 3.773320855}
(2)
fsolve_elapsed_seconds:= time[real]()-fsolve_start;
0.50e-1
(3)
###warning, the following command may crash and/or execute indefinitely###
solve(sys);
solve_elapsed_hours:=(time[real]()-solve_start)/3600;
Download solve-fsolve-primes.mw
Maple 2023.1 includes improvements to the math engine, Plot Builder, import/export, and moreWe recommend that all Maple 2023 users install this update.
This update is available through Tools>Check for Updates in Maple, and is also available from the Maple 2023.1 download page, where you can find more details.
In particular, please note that this update includes fixes to problems with Quantifier Elimination and Group  Theory, and improves performance after a period of inactivity, all of which were reported on MaplePrimes. Thanks for the feedback!
At the same time, we have also released an update to MapleSim, which contains a variety of improvements to MapleSim and its add-ons. You can find more information on the MapleSim 2023.1 download page.
1 2 3 4 5 6 7 Last Page 1 of 64
