Question: Solving a set of ODE's
I'm currently trying to solve a set of ODE's using dsolve/numeric and I'm unsure about the result I'm getting.  Some help with the worksheet and general help with the solution method would be appreciated.
Here are the equations:
 diff(b1(t), t) = I*u1(t)
diff(b2(t), t) = I*u2(t)-3*b1(t)/(2*omega)
diff(b3(t), t) = I*u3(t)
diff(u1(t), t) = I*b1(t)+2*u2(t)/omega-gradQ1
diff(u2(t),t)=I*b2(t)-1/(2*omega)*u1(t) - gradQ2
diff(u3(t), t) = I*b3(t)+I*b3(t)-gradQ3
Where ω and κ are parameters (nominally, I can set them to 0.125 but would like to be able to change them around later).
gradQ is defined as:
gradQ2 = (3*K*u2(t)-2*u1(t)*omega)/((9/4)*K+omega^2+omega^2/kappa^2)
gradQ1 = 1.5 * K * gradQ2/ω
gradQ3 = gradQ2/κ
and K = (x + t)
The initial conditions are:
b1(0) = exp(-(1/25)*ln(2)*x^2), b2(0) = (3/25*I/ω)*ln(2)*x*exp(-(1/25)*ln(2)*x^2), b3(0) = 0, u1(0) = 0, u2(0) = 0, u3(0) = 0
I would like to integrate these equations from x = -64..64 and from t=0..16
The command I've been using is dsolve passed with the numeric and parameters=[x] options.
Again, any help is much appreciated.
