Question: Numerical integration of procedures
somehow Maple does not integrate a procedure in the correct way. And I don't know why. Could you please help?
This procedure creates a matrix of a special form
P:=proc(n,k,A,d,Lambda)
local p,i,j,m,off,eps:
if n<6 then print("n greater 6"): return: end if:
if (n mod 4)<>2 then print("n has to be n (mod 4) = 2 "): return: end if:
eps:=proc(m,A,Lambda,k) (k+m*Lambda*2)^2+A/2 end proc:
p:=Matrix(n,shape=symmetric):
off:=(n-2)/4:
for i from 1 to n do
for j from 1 to i do
m:=trunc((i-1)/2)-off: #print("m",m):
if i=j then      p[i,j]:=eps(m,A,Lambda,k)*(-1)^(i+1):
elif i=j+1 then
 if type(i,even) then p[i,j]:=-d end if:
elif i=j+2 then      p[i,j]:=A/4*(-1)^(i+1):
else      p[i,j]:=0:
end if:
end do:
end do:
p;
The next procedure calculates eigenvalues and add them
lambdak:=proc(k,n,A,d,Lambda) uses LinearAlgebra:
local lambda,lambda0,intw:
lambda:=Eigenvalues(P(n,k,A,d,Lambda)):
lambda0:=Eigenvalues(P(n,k,A,0,Lambda)):
intw:=add((abs(lambda[j])-abs(lambda0[j])),j=1..Dimension(lambda)/2);
The next procedure integrates the last procedure over k
intk:=proc(d,n,A,Lambda)
local k,l:
evalf(Int('lambdak(k,n,A,d,Lambda)',k=0.0..1.0));
Then we evaluate it
intk(2.,14,1.,1.);
But this result is wrong which can you see from the plot of the function.
plot('lambdak(k,14,1.,2.,1)', k= 0...1);
Thank you for your help.
Download EvalfInt.mw
