Question: Plotting Region Based on Boolean Expression
I am looking for an implementation of the Mathematica equivalent of RegionPlot whose description should be like:
RegionPlot(pred,x=x_min..x_max, y=y_min..y_max) makes a plot showing the region in which pred is True.
For example, I would like to execute:
> RegionPlot(f(x,y) > 0 and g(x,y), x=x_min..x_max, y=y_min..y_max)
where g(x,y) outputs True/False.
One idea I had was to use:
> densityplot(`if`(pred,1,0), x=x_min..x_max, y=x_min..x_max, brightness=1, style=patchnogrid);
The problem lies in the fact that to get a "nice" plot I need to use a really fine grid on densityplot which makes the graphics generated extremely cumbersome. The ideal solution will probably use implicitplot with filled=true.
