Question: substitution a number
Hello, I have a problem, when I define some constants like a:=5, b:=6 and than I do some calculation like a+b maple shows immidiately the solution. Is there any way how to make maple to show the numbers at first and then the solution? What I mean is if I define the same constants a:=5, b:=6, then make the calculation a+b. The output i want would be 5+6=11. Is it possible to make maple show the solution this way? I use it for more complex calculation in civil engineering and I need to see with which numbers I am calculating, so it is easier to estimate solution and correct mistakes. Thank you for answer
