Question: 2d Math - Numerical integer with index
HI,
at first I have to admit, that I'm totaly new to maple and have only few experience with the programm.
That's the problem. I've got an old maple-code which I want to rewrite in the 2d-Math-syntax. In the code there are a lot of variables of the type "numerical integer" with a form like
"rho_a"
"N_A"
--> with index in the name
It's a code for a physical-/chemical- process so the index in the name of the variable is important. But at the moment I add an index for the variable, the type is changed from "numerical integer" to "table". Is there any possibility to hard-define the variable as an "numerical integer" that it will not be changed?
thanks a lot!
