Question: Animate using numeric data
For a beam vibration problem I want to animate a function w composed of a time dependent part p(t) and a coordinate dependent part W(x).
w(x,t)=W(x)*p(t)
The coordinate dependent part is an analytical function, but the time dependent part is sequence of a cetrain length with numeric data [{value},{time}]. The code that I used for animating a fully analytical function therefore can't work anymore.
w := W*p:
with(plots): animate(w, x = 0 .. L, t = 0 .. 2.5, frames = 200, numpoints = 100);
Any suggestion on how to use the numeric data in an animation would be much appricated.
Regards, Erik.
