Question: What does the output of eliminate mean?
I was using "eliminate" to combine a set of equations removing some variables and getting a clearly wrong result. So I looked at the docs and the first example, and I find I don't understand its result either. Here is the example:
sol:=eliminate( {x^2+y^2-1=0, x^3-y^2*x+x*y-3=0}, x); # eliminate x from this set & leave one eqn of y
This returns:
which is the same as in the docs. My understanding is that the 1st set is the equation for x in terms of the other variables and the last set is the resultant eqn with x eliminated. Now I check by substitution of x in the original eqn:
simplify(subs(op(1,sol),x^3-y^2*x+x*y-3));
and I get
clearly not what was returned from eliminate; although its expression is in here. Note that I can replace "=0" in the equations by something else (a variable) and find the result of eliminate still disagrees with the substitution.
What am I missing??
Mac Dude
