Question: Extracting values from odeplot
Assume having to solve an ode with dsolve and plotting with odeplot. Further, markings at specific parameter values of the solution should be plotted, i.e. if p is the solution of the ode, the points p(t1), p(t2), ... should be plotted. Since the ode is complicated and computation takes a lot of time, is there a way to extract the values p(t1), ... from the odeplot result directly without invoking calls like subs(p(0.5),b(s)) again?
