Question: define shows unexpected behavoir
I'm trying to use define but get unexpected behavior. Say I want to declare that the map phi is additive. I would try this
define('phi',phi(x::`+`)=map(phi,x));
But if I do phi(x+y) now, I get a warning about an infinite recursion. I get an indication of what the problem is if I define instead
define('phi',phi(x::`+`)=op(x));
Now phi(x+y) produces "x+y" rather than "x,y", so somehow the sum is considered atomic. Can somebody explain this to me?
In fact, I want phi to be linear in the end, so you might wonder why I don't just use the keyword 'linear'. The short answer is, I want to understand what's going on in the example above. The long answer is, I also want phi to map a certain element sigma to itself. But if I define
define('phi','linear',phi(sigma)=sigma);
Then phi(x*sigma) does not reduce to phi(x)*sigma and neither does it with
define('phi','linear',phi(x::name sigma)=phi(x) sigma);
So, if somebody can explain this to me, I'm gratefull, too.
Finally, here is another surprise. After
define('sigma',sigma^3=Z);
entering sigma^3 produces sigma^3, not Z.
