Question: subs and raise to power of
Hi!
Im having some weird results when using either subs or sum with a variable able to take on different values. I have been able to reduce the problem into the following:
>subs(x=0, 0^x )
 answer: 0
But when i simply type:
> 0^0
the answer is the correct:  1
Why is this happening? (same thing often also occurs when i use sum, eg it says that sum(0^x * a , l=-3..3 ) = 0 , when clearly the answer should be a )
And more importantly , how can i write this so that maple understands?
