Question: How to save data in vectors ?
HI folks ! I'm new to this forum and I have a problem with the Euler Method to solve equations.
In the method, there are 3 variables, x, v and t. I need to save the result from every step from the method of the 3 variables and then create a matrix with 3 columns (one for each variable) and any amount of lines.
Is is the best way to do it ? I'm having a lot of trouble at storing data into vectors.
To clarify my problem, here is my program:
dt := 0.1e-2;
 xo := 1; vo := 0; vec := [xn, vn, t]; omega2 := 1;] i := 1;
 for i to 1000 do i
xn := xo+vo*dt;
vn := vo-omega2*xo*dt;
t := i*dt;
xo := xn;
vo := vn;
 xf := [op(vec), [xn]];
 vf := [op(vec), [vn]];
tf := [op(vec), [t]]
> B := Matrix([xf, vf, tf]);
In the Matrix B, after storing the vectors into it I have only 3 lines filled instead of 1000 (i). And another problem is that in the 3 lines, each column has the same value. It's appearing like this:
[[0.5405728050,-0.8418916460,1.000,[0.5405728050]],[0.5405728050,-0.8418916460,1.000,[-0.8418916460]],[0.5405728050,-0.8418916460,1.000,[1.000]]]
I really don't know what to do. So, any help to solve my problem or another method to do the same would be really great ! Thanks alot !
