Question: Two Separate Procedures - Plotting on the same graph.
I have two separate procedures, one which solves a series of ODE's using the midpoint runge-kutta method, and one which solves using the Taylor expansion.
I am able to graph the two results (Q1 vs time) on separate graphs within the procedure, however after "end proc" I can't retrieve the figure or plot the two seperate results on the same graph to compare the values.
Is there an easy way of doing this or do I have to rewrite the procedure to include both methods?
Thanks for any help.
