Question: Problem using "restart" command typed at the command prompt in classic mode worksheet
I sometimes like to work with worksheets in classic mode. However, I have just discovered that I cannot simply type "restart;" in the beginning of a worksheet in classic mode because it causes the worksheet window to freeze. However, if I click the "restart" button, then things go as normal. I really want to have each of my worksheets begin with the "restart;"  command. Need your assistant on a way out.
I use 64-bit windows 7 CORE i3 Dell Inspiron N4050.
Thanks.
Ib
