Question: Division by zero problem with DAE (dsolve)
I'm trying to solve a pretty complex system of equations (a 3rd order DAE with 61 equations) using the MEBDFI numeric solver but I'm always getting the following error.
error in dsolve/dae/numeric/sm_intersect. numeric exception, division by zero
I have tried to find out what the sm_interesect command is but I haven't had luck neither in Internet nor in Maple help. I have looked for similar posts about the division by zero problem in dsolve and it seems that it could be solved with different initial conditions
Can you help me? I would like to know what the sm_intersect command is and if there is a way to locate the equation that is causing this division by zero problem because it's not evident.
Thank you very much
