Question: API Programming with Maple16 under Linux (openSUSE 12.2); no evaluation within maple
I have currently trouble running existing C-code in a new Linux (64 bit) system with Maple16. I have code that used work just fine, now it fails to evaluate. As an example, statements like
EvalMapleStatement(kv,"1+1+2^3;");
still work as expected and return a number. However, code like
EvalMapleStatement(kv,"int(x, x=0..1);");
returns int(x, x=0..1), i.e. a string, which causes my program to crash, because a number is expected.
I have set the LD_LIBRARY_PATH  environment varibale according to what I see when I execute in xmaple
getenv(LD_LIBRARY_PATH)
Also the MAPLE environment variable has been set correctly (/usr/local/bin/maple16).
I have installed maple16 several times in different directories, the error remains.
In order to get the compilation and the execution to work, I had to place a symbolic link libgmp.so
in the directory where my executable resides which directs to the same source as the link in
the correct /usr/local/bin/maple........ directory.
At the moment I am running out of ideas as to what else I could try.
Can anyone provide some ideas or even solutions for me?
Best,
mank
