Question: Command Explore - Add Color, Labelsdirection, Gridlines, etc.
Hello,When I plot graphs I can simply add colors, gridlines, labels, etc., but when I want to do this with the command 'Explore' it doesn't work.The commad 'Explore' sees the words 'color', 'labeldirections' and other commands as extra variables.For exmaple is does recognize 'labels' and 'title', which I can fill in, but it doesn't some of the other commands I would like to insert.I have a formula for deriving the eigenfrequency of a concrete beam, where I want to add some things to (like the things mentioned above).Somebody knows what the difference is between 'normal' plotting and plotting with 'Explore'?Explore_-_Adding_Col.mwGreetingsFrank
