Question: How to hide the warning message and continue last statement in c#
1.
Actually the goal is to output a numeric to c# variable after run a procedure
i use EvalMapleStatement to run the procedure body and then
use another EvalMapleStatement to call this procedure
it do not know the procedure or variable in last EvalMapleStatement
2.
then i think whether i can run it once with one EvalMapleStatment
however i got maple warning about declared local variables to procedure
so, the output with c# function cbText is a x box
