Question: Definition of universal joint and spherical joint with spring element
I need to model universal joint and spherical joint with spring elements.
Contrary to the revolute joint where there is an option to put spring element, i don't find this option in the universal joint and the spherical joint. So is there a simple solution to model spring in this kind of joint.
I hope that i shouln't have to build the joint with several revolute joint in serial.
Thank you for your help.
