Question: Newton-Raphson formula
Assume that |T(z)| < 1. Why does it follow that (T(z))r → 0 as r → ∞?
(Hint |(T(z))r| = |T(z)|r.) Deduce from the above that, as k→∞, we have T(Nk(z)) → 0. Why does it follow that Nk(z)→i ?
What is the corresponding result when |T(z)| > 1 ?
(Hint: Let l/T(z) = U(z)so that |U(z)| < 1, then apply the same argument (check U(N(z)) = (U(z))2noting that U-1(0) = -i).
Now consider the two regions of the plane:
R+ = {Nk{z) → as k → ∞}; R- {Nk(z) → -i as k → ∞}.
Draw a diagram to illustrate these regions, the line L and the roots and -i. We call R+ the basin of attraction for the root +i, and similarly R-is the basin of attraction for the root -i.
Show that if is on the set (the common boundary of the two regions R+ and R_, then Nk(z) stays on L for all values of k. (This is easy once you identify what is). So in this case iteration does not produce a root at all.
It would be appreciated if any one could help me with clear up my confusion with questions.
Thanks a lot.
