Question: Maple and its parallel capabilities => Parallella?
I've found the following project: http://www.parallella.org/
It is a very cheap but impressive computer ( 64-cores, they say it gives about 90 GFLOPS of computing power). The problem is the very limited amount of memory (1GB). See: http://www.parallella.org/board/ for specifications.
Now my question is: do you think Maple will run on this machine (acoording to the site it will run Ubuntu) and if so then does it make sense to try it given the small amount of memory it has? Or in another words: do there exist problems that could be solved by Maple on this powerful machine and that cannot be solved on a regular machine with let's say 4GB of RAM?
