Question: Error, (in LA_Main:-Eigenvectors) cannot determine if this expression is true or false
expect to calculate a eigenvector in terms of variable test10
close3 are decimal value
> NewMatrix3 := Matrix([[test10, close3(t), close3(t+1), close3(t+2), close3(t+3), close3(t+4)], [close3(t), close3(t+1), close3(t+2), close3(t+3), close3(t+4), close3(t+5)], [close3(t+1), close3(t+2), close3(t+3), close3(t+4), close3(t+5), 0], [close3(t+2), close3(t+3), close3(t+4), close3(t+5), 0, 0], [close3(t+3), close3(t+4), close3(t+5), 0, 0, 0], [close3(t+4), close3(t+5), 0, 0, 0, 0], [close3(t+5), 0, 0, 0, 0, 0]]); New_Asso_eigenvector := Eigenvectors(MatrixMatrixMultiply(Transpose(NewMatrix3), NewMatrix3));
Error, (in LA_Main:-Eigenvectors) cannot determine if this expression is true or false: abs(149.8198+5.59*Re(test10))+27.38*abs(Im(test10))+abs(118.8174+5.74*Re(test10))+abs(90.3603+5.49*Re(test10))+abs(61.9327+5.19*Re(test10))+abs(31.0804+5.37*Re(test10)) < (1/10)*abs(149.8198+5.59*Re(test10))+2.738000000*abs(Im(test10))+(1/10)*abs(118.8174+5.74*Re(test10))+(1/10)*abs(90.3603+5.49*Re(test10))+(1/10)*abs(61.9327+5.19*Re(test10))+(1/10)*abs(31.0804+5.37*Re(test10))
