Question: Multithreaded calculation
Hello, everyone. I have some problem with multithreaded calculation. I just need calculate eigenvalues of matrix m at various parameters (and then export to a file) using advantages of the parallelizing. The following code works but in serial way
restart: with(LinearAlgebra):
m:=ImportMatrix(cat(currentdir(),"m.txt")): # here is matrix m.txt
step:=1:
prc:=proc(k1,k2)
local u,i,j,nmc:
u:=Matrix(ceil(1+(k2-k1)/step),5):
u[1,1]:=k1:
for i from 2 to op([1,1],u) do
u[i,1]:=u[i-1,1]+step:
end do:
for i from 1 to op([1,1],u) do
nmc:=sort(Eigenvalues(m*u[i,1], output='list')):
for j from 2 to op([1,2],u) do
u[i,j]:=nmc[j-1]:
end do:
writedata[APPEND](cat(currentdir(),"u_",convert(k2,string),".txt"), [convert(Re(u[i]),list)]):
print(u[i,1]);
end do:
return finished:
with(Threads[Task]):
Start(ArrayTools[Concatenate], 2, Task=[prc,1,20], Task=[prc,20+step,40]);
quit:
The Start(ArrayTools[Concatenate], 2, Task=[prc,1,20], Task=[prc,20+step,40]) function makes two tasks of calculation at the parameter ranges of 1-20 and 21-40. But in this case Start spends twice more time than simply prc(20+step,40). How to realize a multithreaded calculation?
By the way I don't need to use a Concatenate function in Start but without any procedure Start doesn't work.
