Question: it can run in maple, however, input string was not in correct format in c#
run a command string in C# by calling maple
it can run in maple if copy into maple
however return input string was not in correct format
String commandstring = "restart;with(LinearAlgebra):with(ExcelTools): filename := "0257.HK";open3 := Import(cat(cat("C://Temp//HK//Transportation//",filename),".xls"), filename, "B2:B100");high3 := Import(cat(cat("C://Temp//HK//Transportation//",filename),".xls"), filename, "C2:C100");low3 := Import(cat(cat("C://Temp//HK//Transportation//",filename),".xls"), filename, "D2:D100");close3 := Import(cat(cat("C://Temp//HK//Transportation//",filename),".xls"), filename, "E2:E100");n := 30;Round := proc(x,n::integer:=1) parse~(sprintf~(cat("%.",n,"f"),x)); end proc: t:=1; gg :=Matrix(n+1,1); ggg :=Matrix(n+1,1); for k from 0 to n do InputMatrix3 := Matrix([[close3[t+1+k] , close3[t+k], close3[t+2+k]],[close3[t+k], close3[t+2+k],0],[close3[t+2+k],0 , 0]]): InputMatrix3b := Matrix([[close3[t+2+k], close3[t+1+k] , close3[t+3+k]],[close3[t+1+k] , close3[t+3+k],0],[close3[t+3+k],0 , 0]]): InputMatrix3c := Matrix([[close3[t+3+k] , close3[t+2+k], close3[t+4+k]],[close3[t+2+k], close3[t+4+k],0],[close3[t+4+k],0 , 0]]): Old_Asso_eigenvector := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3)): Old_Asso_eigenvector2 := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3b), InputMatrix3b)): Old_Asso_eigenvector3 := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3c), InputMatrix3c)): gg[k+1,1] :=Old_Asso_eigenvector[2][1,1]; od;Round(Re(gg[1,1][1,1]));";
