Question: Parallel Add cause kernel connection lost
If i use expression with function add() it runs normaly, but if I use expression with Threads:-Add (parallel implementation) it causes error "Error, continuation task already created for the current task" or "Kernel connection has been lost"
Expression:
Array(1 .. N,1 .. 1/2*N-NR-1,(i, m) -> evalf(Add(cosArr2[modp(k*i,N)]/kl[k],k = 1 .. NR+m-1)+Add(cosArr2[modp(k*i,N)]*alpha[k],k = NR+m .. 1/2*N)))
What am I doing wrong? Can I use two Add in one evalf?
