Question: differential equations +plot scale
Hell
I write this code and didn't work , I have some erorrs as
Warning, The use of global variables in numerical ODE problems is deprecated, and will be removed in a future release. Use the 'parameters' argument instead (see ?dsolve,numeric,parameters)
Warning, cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up
also I have question " How I can change the scale of plot"
parameters := [z = 0, Omega = 2.2758, tau = 13.8, T2 = 200, omega0 = 1, r = .7071, s = 2.2758, H = 1.05457173*10^(-34), omega = .5, k = 1666666.667, Delta = 1.7758]
sys1 := {diff(u(t), t) = s*v(t)-u(t)/T2, diff(v(t), t) = -s*u(t)-2*Omega*exp(-r^2/omega0^2-t^2*1.177^2/tau^2)*cos(kz-`ωt`)*w(t)-v(t)/T2, diff(w(t), t) = 2*Omega*exp(-r^2/omega0^2-t^2*1.177^2/tau^2)*cos(kz-`ωt`)*v(t)}; ICs1 := {u(-20) = 0, v(-20) = 0, w(-20) = -1}
ans1 := dsolve(`union`(eval(sys1, parameters), ICs1), numeric, output = listprocedure); plots:-odeplot(ans1, [[t, u(t)], [t, v(t)], [t, w(t)]], t = -20 .. 20, legend = [w, v, u])
U := eval(u(t), ans1); F := eval(((-2*10^33*Omega*H*r*U(t))*(1/omega0^2))*exp(-r^2/omega0^2-t^2*1.177^2/tau^2)*cos(kz-`ωt`), parameters)
plot(F, t = -20 .. 20)
