Question: How to use calculate the roots of a function by bisecting the roots of another function?
I wish to be able to calculate the roots of the function f(p) by using the roots of the function h(p) and applying the bisection method due to the fact that the roots of h(p) bracket the roots of f(p) as can be seen in the graph below. I have done this before for another example when h:=J0(p); and hence i could use The commands BesselJZeros(0,n)/BesselJZzeros(0,n+1) to find the roots. So my problem arises with the finding the roots of h(p) and how to insert them into my bisection loop(underlined below).
Any advice would amazing. Many thanks
Digits := 30:
with (plots):
with(RootFinding):
#Define given parameters
R:=1: #external radius of particles, cm
d:=10^(-3): #diffusivity cm^2 per second
alpha:= 1: #fractional void volume
c0:=10^(-6): #concentartion of soltion in void volume of solid initially, moles per liter
C0:=0: #concentration of main body of solution initially, moles per liter
k1:=0.5: #constant in adsorption isotherm (ka)
k2:=0.75: #constant in adsorption isotherm (kd)
k:=2.5: #equilbrium constant for adsorption kinetics
n0:=(k1/k2)*c0:#initial amount absrobed on solid, moles per liter
V:=0.1: #volume of external solution, liters
W:=0.1: #weight of absorbant, grams
rho:=2.0: #solid aparrant density, g/cc
delta:=(1/d)*((p+alpha*k2+k1)/(p+alpha*k2));
beta:=W*alpha*d/(rho*V);
1000*(p+1.25)/(p+.75)
0.500000000000000000000000000000e-3
f:=p->(BesselJ(0,R*sqrt(-delta*p))*k*p-(R*sqrt(-delta*p))*BesselJ(1,R*sqrt(-delta*p))*(d*p/R + 2*beta*k/(R^2)));
proc (p) options operator, arrow; BesselJ(0, R*sqrt(-delta*p))*k*p-R*sqrt(-delta*p)*BesselJ(1, R*sqrt(-delta*p))*(d*p/R+2*beta*k/R^2) end proc
h:=p->(BesselJ(0,R*sqrt(-delta*p)));
plot([f(p),h(p)],p=-0.3..0,axis=-5..5,legend=["f(p)","h(p)"]);
proc (p) options operator, arrow; BesselJ(0, R*sqrt(-delta*p)) end proc
(3)
points:=5:
rts:= Array(1..points):
for n from 1 by +1 to points do
pl:=evalf(#**first root of h**);
pu:=evalf(#**second root of h, i.e n+1 root**);
pe:= (pl+pu)/2;
while abs(f(pe))>10^(-6) do
pe:=(pu+pl)/2;
if f(pu)*f(pe) <0 then
pl:=pe;
elif f(pl)*f(pe)<0 then
pu:=pe;
end if;
od;
rts[n]:=pe;
od;
rts[n]:=p[n];
Download spherical_continue.mw
