Question: widen the region of convergence
Dear collegues
I wrote the following code
restart:
Digits := 15;
a[k]:=0;
b[k]:=7.47;
a[mu]:=39.11;
b[mu]:=533.9;
mu[bf]:=9.93/10000;
k[bf]:=0.597;
ro[p]:=3880 ;
ro[bf]:= 998.2;
c[p]:= 773;
c[bf]:= 4182;
#mu[bf]:=1;
Gr[phi]:=0; Gr[T]:=0;
#dp:=0.1;
Ree:=1;
Pr:=1;
Nbt:=cc*NBTT+(1-cc^2)*6;
slip:=0.1;         ####
NBTT:=2;           ####
lambda:=0.1;       ####
phi_avg:=0.02;    ####
eq1:=diff( (1+a[mu]*phi(eta)+b[mu]*phi(eta)^2)*diff(u(eta),eta),eta)+dp/mu[bf]+Gr[T]*T(eta)-Gr[phi]*phi(eta);
eq2:=diff((1+a[k]*phi(eta)+b[k]*phi(eta)^2)*diff(T(eta),eta),eta)+lambda*T(eta)/k[bf];
eq3:=diff(phi(eta),eta)+1/Nbt*diff(T(eta),eta);
Q:=proc(pp2,fi0) local res,F0,F1,F2,a,INT0,INT10;
global Q1,Q2;
print(pp2,fi0);
if not type([pp2,fi0],list(numeric)) then return 'procname(_passed)' end if:
res := dsolve({subs(dp=pp2,eq1)=0,eq2=0,eq3=0,u(0)=slip*D(u)(0),u(1)=-slip*D(u)(1),D(T)(0)=0,D(T)(1)=1,phi(0)=fi0}, numeric,output=listprocedure,continuation=cc);
F0,F1,F2:=op(subs(res,[u(eta),phi(eta),T(eta)])):
INT0:=evalf(Int(F0(eta),eta=0..1));
INT10:=evalf(Int(F0(eta)*F1(eta),eta=0..1));
a[1]:=evalf(Int(F0(eta),eta=0..1))-Ree*Pr;;
a[2]:=INT10/INT0-phi_avg;
Q1(_passed):=a[1];
Q2(_passed):=a[2];
if type(procname,indexed) then a[op(procname)] else a[1],a[2] end if
Q1:=proc(pp2,fi0) Q[1](_passed) end proc;
Q2:=proc(pp2,fi0) Q[2](_passed) end proc;
Optimization:-LSSolve([Q1,Q2],initialpoint=[0.3,0.0007]);
se:=%[2];
res2 := dsolve({subs(dp=se[1],eq1)=0,eq2=0,eq3=0,u(0)=slip*D(u)(0),u(1)=-slip*D(u)(1),D(T)(0)=0,D(T)(1)=1,phi(0)=se[2]}, numeric,output=listprocedure,continuation=cc);
G0,G1,G2:=op(subs(res2,[u(eta),phi(eta),T(eta)])):
TTb:=evalf(Int(G0(eta)*G2(eta)*(G1(eta)*ro[p]*c[p]+(1-G1(eta))*ro[bf]*c[bf] ),eta=0..1))/evalf(Int(G0(eta)*(G1(eta)*ro[p]*c[p]+(1-G1(eta))*ro[bf]*c[bf] ),eta=0..1));
with(plots):
odeplot(res2,[[eta,phi(eta)/phi_avg]],0..1);
odeplot(res2,[[eta,T(eta)/TTb]],0..1);
odeplot(res2,[[eta,u(eta)/(Ree*Pr)]],0..1);
res2(1);
Nuu:=(1/TTb);
1/((1+a[k]*G1(1)+b[k]*G1(1)^2)/(1+a[k]*phi_avg+b[k]*phi_avg^2));
(1/TTb)*(((1+a[k]*G1(1)+b[k]*G1(1)^2)/(1+a[k]*phi_avg+b[k]*phi_avg^2)));
I want to run the code for the value of NBTT in the range of 0.2 to 10. this code gave the results in the range of 4-10 easily. So, I used the continuation which improve the range of the results between 2-10. However, I coudnt gave the results when 0.2<NBTT<2. Would you please help me in this situation.
Also, It is to be said that the values of phi should be positive. in some ranges, I can see that phi(1) is negative. Can I place a condition in which the values phi restricted to be positive.
Thanks for your attentions in advance
Amir
