Question: linear system solve
I have a linear system to solve.
mm:=proc(a,x,h,i)
local A,Z1,Z2,Z,F,result;  # to declare the local variable
A:=array(1..2,1..2,[[1,1],[a,a+h]]);
Z1:=evalf(int(1/(abs(y-x)+.000000001),y=a..a+h));
Z2:=evalf(int(y/(abs(y-x)+.000000001),y=a..a+h));
Z:=array([Z1,Z2]);
F:=evalm(inverse(A)&*Z);
result:=F[i]
end:
My questions:
1) My exact Z1 is Z1:=evalf(int(1/(abs(y-x)),y=a..a+h)); but I ask if can I put
the same for Z2.
2) Can I writte in a simple form the vector Z.  Because, later, il have a second system contains Z1,Z2, Z3, Z4,Z5.  The difference between Z1 and Z2 is the variable "y" added in the integral of Z2.
Many thinks.
