Question: Error with pdsolve()
I'm trying to resolve a PDE using pdsolve().
The equation is :
diff(n(z,t),t)+diff(n(z,t)*v(z,t),z)=0
where n is the density of particles in a container and v their velocity.
I assume that the density decreases linearly at t=0 : n(z,0)=n[max]*(1-z/H) where H is the height of the container.
This gives the following system :
> sys := [diff(n(z, t), t)+(diff(n(z, t)*v(z,t), z)) = 0, n(z, 0) = k_1*(1-z/H)]
With a velocity of the form :
v(z,t) = (1/tau)(1/n(z,t)-1/n[max])
it works like a charm.
However, I would like to try a velocity of the form :
v(z,t) = v[max]*(1-(n(z,t)/n[max])^5)
(similar to Greenshield model).
pdsolve() raises an error when I try :
> sys := [diff(n(z, t), t)+k_2*(diff(n(z, t)*(1-(n(z, t)/k_1)^5), z)) = 0, n(z, 0) = k_2*(1-z/H)];
> pdsolve(sys);
"Error, (in pdsolve/BC/1st_order/_Fn/integrate) invalid input: op expects 1 or 2 arguments, but received 0"
op(sys) returns the expected result, so I guess the problem comes from the power.
Have you guys have any solution ?
Thanks a lot.
