Question: how to convert back to matrix form
with(combinat):
symMonomial := proc(test)
h := 0;
for i from 1 to nops(test) do
                h[i] := choose(test,i);
od;
c := copy(test);
k := 0;
for k from 1 to nops(test) do
                c[k] := 0;
                for i from 1 to nops(h[k]) do
                                ki := 1;
                                for j from 1 to nops(h[k][i]) do
                                                ki := ki*h[k][i,j];
                                od;
                                c[k] := c[k] + ki;
                od;
od;
return c;
sympoly := proc(test, number_of_roots)
with(combinat):
h := 0;
                h[i] := choose(z,i);
od;
c := 0;
                c[k] := 0;
                                ki := 1;
                                                ki := ki*h[k][i,j];
                                od;
                                c[k] := c[k] + ki;
                od;
od;
poly := x^number_of_roots;
for k from 1 to number_of_roots do
                poly := poly + c[k]*x^(number_of_roots-k);
od;
z := [x1, x2, x3, x4, x5, x6, x7, x8, x9, x10];
sigma := symMonomial(z);
f := expand(sigma[1]*sigma[2]);
f := expand(sigma[1]*sigma[1]); # two lambda value are the same
f := expand(sigma[1]*sigma[1]*sigma[1]); # three lambda value are the same
f := expand(sigma[1]^2+2*sigma[1]*sigma[2]+sigma[2]);
f := subs(x1=3, f);
f := subs(x2=2, f);
f := subs(x3=3, f);
f := subs(x4=4, f);
f := subs(x5=5, f);
f := subs(x6=6, f);
f := subs(x7=7, f);
f := subs(x8=8, f);
f := subs(x9=9, f);
f := subs(x10=lambda, f);
evalf(solve(f, lambda));
if degree(f) = 2 then
                f := f + lambda^3;
end if:
how to convert above f back to matrix form such as
m := Matrix([[a1,a2,a3],[a4,a5,a6],[a7,a8,a9]]);
m-Matrix([[lambda,0,0],[0,lambda,0],[0,0,lambda]]);
m2 := Determinant(m-Matrix([[lambda,0,0],[0,lambda,0],[0,0,lambda]]));
after tested m2 can not be expressed in terms of shell like polynomial,
it seems that it is from symmetric polynomial and it is from a non-homogenous polynomial which homogenize with a lambda
if solve f for new eigenvalue,
can traditional eignvector method calculate new eigenvector for these new kind of eigenvalues method?
A*x = lambda*x
