Question: Partial Differential
Hi All,
I have a problem with regard to partial differential equations. I am using Lagrangian dynamics for a problem. First i have a function First i defined a function with two speeds of angles (first derivatives):
ODE := 5*(diff(theta1(t), t))+diff(theta2(t), t). This gives:
Now this gives an output. Lagrange (just a simple example now) demands that i now derive the obtained function with regard to the first derivative of theta1. In this case, the answer i want is 5. Now, if i give the command:
diff(ODE, diff(theta1(t),t)), maple says go home. Does anybody know how to solve this? I have been searching for a solution all afternoon.
Thnx in advance!
