Question: simplification of complex exponentials
How do I make "simplify" function to recognize complex exponentials. Maple created some exponentiol functions with a square root of negative expression in the denominator of the exponent. It refuses to simplify it. If I manually edit it, by taking negative sign under the root and adding immaginary number, the simplification works. How do I simplify it without manual edit?
The Eq 33 is manually edited line. Simplify function correctly uses cos function.
The Eq 34 is original expression. I tried to tell maple to assume real numbers hoping that it will wotk, but it did not.
