Question: differential equation system
With your help I have a solution to a system of three equations:
(parameters are calculated on the basis of the data (for different values) - one example below)
A1=0.00002072968491, A2=0, A3=0.001946449287, A4=0.01946449287
B1=, B2=0, B3=0.0004773383613, B4=0.00004773383613
C1=, C2=0, C3=, C4=0.00009087604510
eqa1: = A1 * (diff (Tg (x), x, x)) + A2 * (diff (Tg (x), x)) + (A3 + A4) * tan (x) + A3 * Tg (x) + A4 * Tw (x) = 0;
eqa2: = B1 * (diff (Tw (x), x, x)) + B2 * (diff (Tw (x), x)) + (B3 + B4) * Tw (x) + B3 * Tg (x) + B4 * tan (x) = 0;
eqa3: = C1 * (diff (Tz (x), x, x)) + (C3 + C4) * Tg (x) + C3 * tan (x) + C4 * Tw (x) = 0;
indets ({eqa1, eqa2, eqa3}) minus {x};
res: = Dsolve (eval ({eqa1, eqa2, eqa3}) union {boundary conditions ??}, numeric);
for k from 0 to 20 evalf (res (k), 4); from;
c1:= 0.524:
c2:=0.05:
m: = 0;
for m from 0 to 20 and
T (m): = c1 * rhs (op (6, res (m))) + c2 * rhs (op (2, res (m))) + (1-c1-c2) * rhs (op (4, res (m))); print (m, T (m)); end to:
How and what type boundary conditions (I was thinking about the simplest or third type) to be able to determine the values on the y-axis on the graph. For example, the values started at -10, and ended at 10 (at a point (x, -10), (x, 10) in the coordinate system for a predetermined x, for example, from 0 to 20 which start at the point (0, -10 ) and stop at the point (20,10)). My main purpose is to collect these three solutions  to one equation T (x) = az * Tz (x) + and * Tw (x) + ag * Tg (x), and the ends of the graph, they should be in the above-mentioned points (0, -10 ) - start and (20,10) - stop.
Now thank you very much for the advice.
Ewa.
