Question: Multiple pointplots
Hi there,
I am trying to display multiple pointplots in the same plot. I would like to either distinguish the plots by their color or by the symbol (square, traiangle, circle) at each data-point. May be both, although I ignore whether using symbols at data-points is possible in Maple.
The plot i would like to achieve is this:
Maple says that my points are not in the correct format: MapleSimulation_test6.mw
My data array N has two parameters, and the free variable. The two parameters are also varied over a certain range. For plotting purposes, I would like to have one of the variables fixed, select three parameters for the other variable, and plot all data-points for them.
The resulting data array N seems to be OK, but I am aware that my attempt for plotting multiple arrays may be wrong. May be pointplot is not even the best choice.
Any ideas?
Thank you,
jon
