Question: Help translating a pseudocode into maple procedure
So the pseudocode I'm trying to translate into maple is for the greedy vertex coloring algorithm.
The pseudo code is:
Initialize:
1. for i = 1 to n do
2. f[i] := 0 (: no color assigned yet to vertex i :)
3. end(for)
Main loop:
4. for i = 1 to n do
5. let f[i] be the smallest positive integer
which is not in the set {f(j) : j ∈ adj[i]}
6. end(for)
7 return f
The closest I've gotten though is:
greedy := proc (G)
local i, j, n, k, L::list;
description "Take simple graph G and return a coloring of the vertices with at most Delta(G)+1 colors";
n := nops(Vertices(G));
L := [seq(x, i = 1 .. n)];
L := subsop(1 = c(1), L);
j := 1;
for i from 2 to n do
L[Vertices(G)[i]] := c(0)
   for k to i do
        if member(Vertices(G)[i], Neighbors(G, Vertices(G)[k])) then j := j+1
       end if;
L[Vertices(G)[i]] := c(j)
return L;
Basically my procedure is returning more than delta+1 colors for most graphs, how can I edit it to fix this? I'm guessing the problem is somewhere in my nested loops. Also, I cannot use commands like greedycolor or isvertexcolorable. Thanks.
