Question: A negative sign quirk in the solution
For some reason it always bugs me that Maple pulls a negative sign out in the solution.
eq:=c=a+b*exp(-k)
solve(eq,k)
The solution is correct, but one would expect it to be written like ..
.. after all that is a more conventional solution, isn't it?
If I type the last equation into Maple it evaluates to
..again slightly unconventional but still correct.  Only if back quotes around the `c-a` are used can we achieve what we would write out on paper.  It would be nice if Maple would output the answer in a conventional manner ... at least in my opinion.
Can we manipulate Maple to evaluate that solution into the conventional answer?
Afterall, Maple is advertising it's "typsetting appears like it would appear in a textbook" and uses standard Math notation.  All I am trying to say is that if Maple advertises as a math standard could we also present solutions in the same manner?
But not to get sidetracked from the question I posed, is there a way we can manipulate that solution into a "handwritten" convention?
