Question: LT programme for equations
I am relatively inexperienced with Maple and would like to either be pointed in the right direction or shown a similar example to my problem for reference.
My problem is I need to write a programme using the below equations
d^2x/dt^2=ax+by
d^2y/dt^2=cx+by
I then have to use the below values to show my programme works
a=b=c=d=1
x(0)=1
Dx(0)=0
y(0)=0
Dy(0)=1
After proving it works I have to apply it to a mass spring system using realistic parameters. Using visual and analytical ways to show findings.
md^2x/dt^2=-kx-k(x-y)
md^2y/dt^2=-k(y-x)-ky
when x and y are the displacement from the equilibrium. Initially the masses are displaced from their equilibrium posistions and released so that
x(0)=a, y(0)=b, Dy(0)=Dx(0)=0
then repeat with different smaller calculations
Any help would be much appreciated
Thanks
