Question: storing a value in a list/array/sequence
I need to convert a base 10 int(defined as num) to its base 3 format using a while loop. I would like to store the remainder of the num%3 to a list/sequence/array in maple. Now, if I were to use a sequence, I would need a pre-defined range. How do I solve this issue?
