Question: Compile Maplesim Model to c-code
Hallo,
I am facing a problem with the c-code generation of maplesim models:
When I am trying to compile a multibody model that contains more than about 80 bodies I get an error "Error, (in GetCompiledProc) internal error: unable to find matching".
Using the code generation template it says "Error in Component cmdGenerateCode eith caption "Generate C code": (in DSN/Pantelides) internal error: unable to find matching"
Has anyone a solution to this?
Edit:
Model: Ref_Model.msim
It is a simple systems of masses connected by spring/dampers.
I am using MapleSim 7.01
The error message occurs when I try to simulate the model in maplesim, too:
Simulating...
Using the Mark II engine
Simplifying system with 600 equations
Simplification removed 0 equations. Remaining equations: 600
Generating simulation code
DAE index reduction
DSN/RunSimulation: internal error: unable to find matching
(in DSN/RunSimulation) internal error occurred during simulation
Simulation failed.
