Question: Shared variables between Maplesim and Maple
is there a way I can use data (variables) from Maple environment in the Maplesim environment.
I have a scirpt in maple that generates the robots joints angles and need to use them in the 3D robot built in maplesim. I know I can export/Import data, but this sounds redundant. Is there a way to simply use an input block as a source of the data in maplesim and have the variable name generated in maple used int. Similar to what Matlab/Simulink does..
thanks.
