Question: Solving for coefficients in polynomial.
This question is 99% similiar to an previously posted question, but this one has a little twist(s).
http://www.mapleprimes.com/questions/200101-Solving-For-Coefficients-Of-Polynomial-Equations
Here is the sample problem. Let's say I have the following equations
e1:=(a+b+1)x^2 + (a+1)*x^4 = 0;
e2:=(a-b)*x+ (a^2 - 1)*x^3 = 0;
One can immediately tell the system is inconsistent because on x^3, we have a = -1,1 but on x and x^2 we have a = -1/2
This is precisely the problem I am facing, my e1 and e2 will eventually get bigger (bigger as in the order of the polynomial will increase) and I keep facing inconsistencies.
However if I could find a way to code it so that I can ask Maple to solve only up to a certain degree it would be great. This will eliminate any inconsistency
For example, using the system I have here, the system is consistent up to order 2 (it will always start from constants and up to a certain power). So I will ask Maple to solve the above system up to order 2.
Here is a pseudocode I have been working on.
For i = 1..2 //this might be increased, but it will of course be finite and probably won't go past 10.
For j = 0..N
//N is the degree of polynomial
f[i]:= coeff(e[i],x,j);
end
end
//the above generates the equations, below will solve it
solve( { f[i], i=1..?} ,{a,b})
Note that the pseudocode assumes e[i] are expressions and not equations set to 0 (which is what I have). Is there an "un"unapply on maple?
edit1: have to sleep  (late where I am! Will check for responses tomorrow) thank you
