Question: Derivative from pdsolve/numeric solution?
Is it possible to somehow extract a derivative from numeric solution of partial differential equation?
I know there is a command that does it for dsolve but i couldn't find the same thing for pdsolve.
The actual problem i have is that i have to take a numeric solution, calculate a derivative from it and later use it somewhere else, but the solution that i have is just a set of numbers an array of some sort and i can't really do that because obviously i will get a zero each time.
Perhaps there is a way to interpolate this numeric solution somehow?
I found that someone asked a similar question earlier but i couldn't find an answer for it.
