Question: the system of differential equations and the selection of initial conditions.
Hello, dear experts.
I have a question...
solve the system of differential equations,where one of the initial conditions need to be chosen so thatcondition is metat the end of integration.
The task is not difficult, but I'm having trouble with the syntax.
1.I can't "pull"the desired function from the solution and find its value at a certain point.
I try to do so:
r_ravn:=s->subs(F,r(s));
evalf(r_ravn(s_end));
evalf(r_ravn(0));
but there is no result
2.In this case,instead of"for"it is better to use a while loop, but again the problem arises 1.
Tell me, please,how to implemen my program.
restart:
R:=0.3:
theta_min:=Pi/6:
theta_max:=Pi/2:
betta_max:=evalf(Pi/180*80);
p:=2*10^5:
theta0:=s->Pi/3/s_end*s+Pi/6:
r0:=s->R*sin(theta0(s)):
s_end:=evalf(R*(theta_max-theta_min)):
sol1:=solve({sin(betta_max)=c/r0(0)},{c});
const1:=0.1477211630;
betta0:=s->arcsin(const1/r0(s)):
betta:=s->arcsin(r(s)/r0(s)*sin(betta0(s))):
A:=s->cos(betta(s))/cos(betta0(s)):
T1:=s->rT1(s)/r(s):
T2:=s->T1(s)*tan(betta(s))^2:
step:=0.001:
delta:=0.001:
for i from 1 to 3000 do
r_min:=0.3-step:
rT1_n:=p*Pi*r_min^2/2/Pi/sin(theta_min):
sys := diff(rT1(s), s)-A(s)*T2(s)*cos(theta(s)),diff(theta(s), s)-A(s)/T1(s)*(p-T2(s)*sin(theta(s)/r(s))),diff(r(s),s)-A(s)*cos(theta(s)),diff(z(s),s)-A(s)*sin(theta(s));
fcns := {rT1(s),theta(s),r(s), z(s)};
F := dsolve({sys,rT1(0)=rT1_n, theta(0)=theta_min,r(0) = r_min, z(0) = 0}, fcns, numeric,output=listprocedure):
r_ravn:=s->subs(F,r(s)):
if abs(evalf(r_ravn(s_end))-R)=delta then break:
print(r_min):
end if:
end do:
evalf(r_ravn(0));
plot([r_ravn(s),r(s)],s=0..s_end);
