Question: Write a function after computing a limit
I have a procedure wich is something like
F:=proc(a,b,l) limit(f(a,b),b=l); end proc;
For my specific problem, the limit always exists and is a well defined function
After that, I would like to generate other functions, depending on F(a,b,l), e.g.:
G:=proc(a,b,N) add(F(a,b,l),l=1..N); end proc;
However, when I tried to do that, Maple inserts in G an unevaluated F, depending on the results of the limits. This makes G not work properly (unevaluated), since the limit is not computed before G. I tried to use some intermediate steps, like using unapply command, but it does not works.
If someone can help, I would appreciate.
