Question: Fsolve fails for some values of parameters
Hi, the fsolve works perfectly fine when otaining SOL2 below. However, as soon as I change the values of paramters (from 0 values in SOL2 to t_prof = .16, t_r = .16, t_w = .16 in SOL3) fsolve simplmy reproduces the eval results and would not solve! Please your help is highly appreciated. Thanks in advance!
eq1 := ((1-s)*w)^(1-gamma)*r^gamma-P_v = 0;
eq2 := (1-s)*w*H/M-(1-gamma)*P_v*q/phi = 0;
eq3 := r*(K+K_f)/M-gamma*P_v*q/phi = 0;
eq4 := prof-M*p_d*q+(1-s)*w*H+r*(K+K_f) = 0;
eq5 := -tau*y_x+q-y_d-y_g = 0;
eq6 := p_d-sigma*P_v/((sigma-1)*phi) = 0;
eq7 := y_d-M^(lambda-1)*Y*(p_d/P)^(-sigma) = 0;
eq8 := y_x-F_f*(tau*p_d)^(-sigma_x) = 0;
eq9 := y_f-M_f^(lambda-1)*Y*((1+z)*tau*p_f/P)^(-sigma) = 0;
eq10 := (G*alpha_g+Y)^(-alpha_c)/P-A*H^alpha_h/((1-t_w)*w) = 0;
eq11 := P*Y-(1-t_w)*w*H-(1-t_r)*r*K-(1-t_prof)*prof+T = 0;
eq12 := P*Y-M*p_d*y_d-M_f*(1+z)*tau*p_f*y_f = 0;
eq13 := (1-t_r)*r-r_f = 0;
eq14 := G-y_g*M^((lambda_g-1+sigma_g)/(sigma_g-1)) = 0;
eq15 := s*w*H+M*p_d*y_g-T-t_w*w*H-t_r*r*(K+K_f)-t_prof*prof-z*M_f*tau*p_f*y_f = 0;
SOL2 := fsolve(eval({eq1, eq10, eq11, eq12, eq13, eq14, eq15, eq2, eq3, eq4, eq5, eq6, eq7, eq8, eq9}, [A = 7.716049383, K = 3.2, K_f = 0, alpha_c = .8, alpha_g = .2, alpha_h = 4, lambda = .5, p_f = 1, phi = .625, s = 0, sigma = 5, sigma_g = 5, sigma_x = 5, t_prof = 0, t_r = 0, t_w = 0, tau = 1.1, y_d = 1, y_f = 1, y_g = .4, y_x = 1, z = 0, lambda_g = .5, gamma = .25, gamma = .25]), {F_f, G, H, M, M_f, P, P_v, T, Y, p_d, prof, q, r, r_f, w}, {F_f = 2 .. 4, G = .1 .. .4, H = .4 .. .8, M = .4 .. .6, M_f = .3 .. .7, P = .8 .. 2, P_v = .4 .. .8, T = -.2 .. .3, Y = .7 .. 3, p_d = .9 .. 1.6, prof = .1 .. .4, q = 1.5 .. 2.7, r = 0.4e-1 .. 0.9e-1, r_f = 0.4e-1 .. 0.9e-1, w = .8 .. 3});
SOL3 := fsolve(eval({eq1, eq10, eq11, eq12, eq13, eq14, eq15, eq2, eq3, eq4, eq5, eq6, eq7, eq8, eq9}, [A = 7.716049383, K = 3.2, K_f = 0, alpha_c = .8, alpha_g = .2, alpha_h = 4, lambda = .5, p_f = 1, phi = .625, s = 0, sigma = 5, sigma_g = 5, sigma_x = 5, t_prof = .16, t_r = .16, t_w = .16, tau = 1.1, y_d = 1, y_f = 1, y_g = .4, y_x = 1, z = 0, lambda_g = .5, gamma = .25, gamma = .25]), {F_f, G, H, M, M_f, P, P_v, T, Y, p_d, prof, q, r, r_f, w}, {F_f = 2 .. 4, G = .1 .. .4, H = .4 .. .8, M = .4 .. .6, M_f = .3 .. .7, P = .8 .. 2, P_v = .4 .. .8, T = -.2 .. .3, Y = .7 .. 3, p_d = .9 .. 1.6, prof = .1 .. .4, q = 1.5 .. 2.7, r = 0.4e-1 .. 0.9e-1, r_f = 0.4e-1 .. 0.9e-1, w = .8 .. 3});
