Question: Problem with printing out values
To begin with my code is:
with(Statistics);
N:=RandomVariable(Normal(5,2))
for i from 1 by 1 to 100 do
OS[i]:=Sample(N,50)
end do
 print(i)
  from j from 1 by 1 to 1000 do
    BS[i,j]:=Bootstrap('Mean',OS[i],replications=1)
  end do
end do
My goal is to produce as an output in the software's screen the values of 1000 bootstrap means for each of 100 original samples in order to export the results to Excel. Based on my basic knowledge of programming I thought that I can do that through the use of the vectors. Unfortunately though when I trigger the operation the software seems to be evaluating (with the homonymous indication in the bottom left corner of the screen) it for an indefinite period of time, obliging me to stop it at some point. However, let me point out that when I do the same process for i and j 4 and 10 for example then I have results, therefore presumably my code is correct. I know that I can do the same operation in Excel and I have already created a respective macro, however I wanted to use Maple in order to take advantage of its fast operation of calculations, which is pointless in case that I have to wait more time for the results than I have already waited to be eventually produced.
Any thought and idea would be appreciated, thank you very much in advance!
