Question: How do I fix the error message ?
I have written a Math App in Maple to create a Math App question in Maple TA.
The app has two tables, a plot area, and text box. The first table provides the data to the students for calculating their answer (and so Editable in the component properties is unchecked). The second table is where the student enters their answers (and so Editable is checked). The text area and plot area are for providing some real time feedback and error checking to the students.
Everything works fine in Maple.
In Maple TA I have tried using both a Math App question type and a Question Designer question type with a Math App inserted. I have tested it in Internet Explorer, Chrome and Firefox.
In all six cases when I click on one of the editable table cells to put in an answer a popup appears with the error message: "Unable to update RTable due to error=TypeError: window.parent.parent.updateRTable is not a function"
I am using Maple 10 and the latest hotfix is SP-002.
What I have worked out so far is that the Maple TA web page is designed so that the Math App sits in an iframe and each table sits in a separate iframe inside that iframe. updateRTable is a function inside the tables iframe that calls the updateRTable on the top level window and if this fails gives the error message above.
The top level window includes the file /maplenet/js/worksheet.js, which includes the function updateRTable.
How do I fix this error?
Thanks
