Question: How to calculate error of calculation?
I'm null in statistic. I'm doing a calculation to calculate a set of parameter. By example:
I have to calculate 5 parameters x1,x2,x3,x4,x5 from 7 equations f1,f2,f3,f4,f5,f6,f7. Because it is difficult to calculate directly 5 parameters, I used chisquare to minimize the difference between experimental and theorical data. Then, I can get the results. After that, I used these 5 parameters to back-calculate the data using 7 equations above. My question is about how to calculate the error bar (or standard error) of the back-calculate datato add to the plot.
Thank you  for helping me,
Best regards.
