Question: Error in using Physics[Vectors]
I am tryng to write and solve within Maple the equations of movement for a single body subject to a gravitatinal field, F_=-GMm/r2
But I get an error message when trying to define the Angular Momentum which doesn't make sense for me.
Thank you for any help on this topíc.
restart; with(Physics[Vectors]); conventions, Setup(mathematicalnotation = true);
conventions, [mathematicalnotation = true]
r_ := rho*_rho;
r_ := rho _rho
_rho(t);
_rho(t)
rho(t);
rho(t)
v_ := diff(rho(t)*_rho(t), t);
/ d \ / d \
v_ := |--- rho(t)| _rho(t) + rho(t) |--- phi(t)| _phi(t)
\ dt / \ dt /
a_ := diff(%, t);
/ 2 \
| d | / d \ / d \
a_ := |---- rho(t)| _rho(t) + 2 |--- rho(t)| |--- phi(t)| _phi(t)
| 2 | \ dt / \ dt /
\ dt /
/ 2 \ 2
| d | / d \
+ rho(t) |---- phi(t)| _phi(t) - rho(t) |--- phi(t)| _rho(t)
| 2 | \ dt /
\ dt /
eq[1] := -G*M*_rho(t)/r^2-a_ = 0;
/ / 2 \ 2\
| G M | d | / d \ |
eq[1] := _rho(t) |- --- - |---- rho(t)| + rho(t) |--- phi(t)| |
| 2 | 2 | \ dt / |
\ r \ dt / /
/ / 2 \
| / d \ / d \ | d |
+ _phi(t) |-2 |--- rho(t)| |--- phi(t)| - rho(t) |---- phi(t)|
| \ dt / \ dt / | 2 |
\ \ dt /
| = 0
Eq[1, 2] := seq(Component(lhs(eq[1]), n) = 0, n = 1 .. 2);
/ 2 \ 2
G M | d | / d \
Eq[1, 2] := - --- - |---- rho(t)| + rho(t) |--- phi(t)| = 0,
2 | 2 | \ dt /
r \ dt /
/ 2 \
/ d \ / d \ | d |
-2 |--- rho(t)| |--- phi(t)| - rho(t) |---- phi(t)| = 0
\ dt / \ dt / | 2 |
\ dt /
NULL;
L_ := `&x`(r_, m*v_);
Error, (in Physics:-Vectors:-&x) found the unit vector _rho present also as a function _rho(t); either one form or the other - not both - can be present in an algebraic expression
